This is my first time building an E Board and I came on to a problem, the pulley that I got for my board has a 10mm hole and the motors that I bought have a 8mm shaft so after trying to buy for the second time a new pulley, the site that i tried to order the pulley never shiped it to me and after the second atempt I decided that I would fix the problem myself and save some money in the process
Lets start
First the problem
Has you can see the pulley is too big for the motor so I had to come up with a solution
And here it is
After a trip to the shop I bought this
A stainless steel pipe with and outer diameter of 10mm and a inner diameter of 8mm
The step back
The pipe is a bit to big for the hole
After a bit of filing, I was able to make the tube enter very snuggly and I had to use a vise to force the tube in
But there is still the problem of the screw holes for the mounting screws
So after a drill the holes with a 3mm drillbit I had to go again to the store to buy to buy some 4mm tapping holes tips and hand tap the holes " didn’t have any 4mm tips"
After a bit of filing to clean the holes
Success! It all fits together!
Give me your opinion on what you think of this mod
Hope you guys like it
You didn’t really explain what you are doing with the rod but it looks like you are going to replace the motor shaft with it? If so just order a pulley that fits your motor shaft, it will save you a lot of time and effort and might keep you from breaking your motor
That’s exactly what I did, my pulleys don’t have a key way but they have two screw holes and I already got the loctite, when i finish my build I will post it, do you think it will hold?
If it works it ain’t stupid. I would suggest you get pullies with an 8mm boar, as you will likely have balance issues but I bet they wont be bad and it’ll likely work forever. Good job.
I have done this before with 6mm shaft and 8mm pulleys. I just drilled and tapped the pipe and added a longer grub screw to go through both. It works great. 1 drop of loctite for it and it was permanant
Hi Duarte,
I believe you live in Portugal and are Portuguese.
Well, i use to live in the US, but now i live in Portugal also.
I’m also building a Trampa based e-MTB. Just finished building a twin jet surfboard. It is great to know there is people near by that enjoy making the same stuff. My email is [email protected]
It would be nice to exchange knowledge.
