Motor pulley!
Bore: 10mm
Width: 12mm or 15mm
shipping to Germany
10mm gear/pulleys are a little hard to find.
Best (but most expensive) is beltingonline.com (in the UK, so somewhat close).
I also find some on ebay you can select 10mm bore from dropdown selection. Almost always aluminum, and no keyway, so just grub screws to hold it (not a problem i’d just add a bit of blue loctite).
GL!
Aps has 15mm pulleys with 10mm bore.
Hey thanks guys. Aps is down till 19th of july so thats too long. I also found them here:
I have 5m 14T , 15T, 16T, 18T, 20T pulleys with 10mm bore, and belts as well
Any motor pulley can have a 10mm bore, if you have access to a lathe. I had to bore out all my motor pulleys to the correct diameter. It only takes a minute. Your local machine shop might even do it for free
Hello Sir, Hope you got product as per your requirements. If you wants various power transmission products like gears, timing pulleys, conveyors, sprockets etc. for different industrial applications then you can contact us.
Thanks,
