I don’t use Turnigy sk3 6374 because they aren’t 6374 but more like 6186 and they aren’t sensored. Before the kv even becomes a factor, it’s disqualified
I have the same motor on a single build with 6s and a xcar beast 150A and it´s great
Nothing wrong with it, but it´s to high on kv for higher Volt boards like a 10 or a 12s.
Im planing my road mountainboard with 200 mm wheels (not really mountainboard, just the pavement surface is too shitty for longboard wheels in my country…hah)
245kV really sounds too much for this use case. Unless you can do a really high reduction.
For example Im using an Emax motor (https://www.emaxmodel.com/gt5345.html) which is I suppose comparable to the 6374 SK3. Mine will be 192 kV and the reduction I’m planning is 1:6, which is nuts compared to the longboard wheeled boards. But this is necessary to not stress the battery too much and have acceptable torque. A guy I know did 1:5 and said it was too low. I think his wheels were smaller as well…
