I have two TB 6355 and before I got the 218mm trucks, they were successfully crammed onto the normal TB caliber 2’s. TB claims that they are actually 6365 motors stuffed into a 6355 case, and while I have no idea if that is true or not, I don’t have a single issue with any hill. I haven’t found one I can’t go up yet.
Partially related, I pull around 30 battery amps from each vesc on hills. I’m about 150 Lbs
There was a post (IDK where I saw it on esb) that showed that 6355 and 6364 motors have the same exact stator sizes. Magnets might be bigger, but not the stator.
Well does this look waterproof to you? I mean sure the motor spinning and centrifugal force may throw water away but what if you stop splash in a puddle.
From what I’ve learned over the years in RC hobbies is that a brushless motor is waterproof just by design…but it’s not dust and dirt proof, with when mixed with water can destroy a motor.
And I know there is very little 100% pure water that will be sitting on the road to ride through but I won’t be using this for commuting, it will most likely just be a fun weekend rider or when I’m board at work go blast up the parking garage a few times!!
Yeah I was just told that by one of the experts on here" and it seems to make sense, as my Traxxas Slash can literally run in a pool underwater and survive.
Exactly. But it will start to damage other things and require you to practice a bit more maintenance over and over throughout the motors life.
What type of slash do you have? I’ve been running what I call a “frankenslash” from all the crap I’ve had to replace on mine from eithe being stupid and breaking something or wanting to go faster!
I think I’m going to just get the 6364 Turnigy motors from hobby king for now.
The only question I have is can those be ran on 12s? It says up to 10s but I read a big thread about how they can still be ran with 12s…not sure though!
I have maytech 6365’s in my opinion some of the best out there or if you can’t wait just buy some of @longhairedboy’s “totally bitchin” motors off his website! https://longhairedboy.com/
