I connected them up to a flipsky dual vesc and after connecting them up they make a weird sort of grinding noise and are extremely stiff around once every rotation (only for a small portion of the rotation)
I couldn’t see under a light any blockage
I tried using the board however it couldn’t anywhere near produce enough torque to even move me a couple of meters
Was the setup previously working with other motors aka have you done a successful motor detection and spin-up. It could be a broken magnet but you would have to open up the motor and send some pics.
Just be careful that you acknowledge the current reverse switch on the gt2b remote before you mess with reverse setttings in the VESC tool. If you don’t mind swinging your board round on pivot to go backwardfs its easier to just run current with brakes no reverse. If you want the reverse function then you need to make sure the switch on the remote is forward and then code with current and model your pulsewidth to that, otherwise you can get problems where you switch direction and the throttle curve doesn’t adjust and the board sends you onto your back.
