was working on my board when I noticed that the wheel pulley was grinding on the mount just a bit. Small sparks whenever I hit the throttle. Was putting it back together and hit the throttle again. Then it spun up and now it doesn’t work anymore.
Setup is a VESC/10s4p/Single motor 6374 190KV/FOC. The BLDC connects without issues. However I can’t manually spin up the motor using the arrow keys or do a motor detection. Is there anywhere I should take a look at ?
Phase wires didn´t come or are loose. I can still read all settings in the BLDC tool and the VESC connects just fine.
Mhmm… It was running in FOC really well the last days. Maybe it could have sth. to do with the update I did today. I flashed the new 2.54 firmware and tool that ackmaniac released. First time doing watt w. reverse and his new mode. That is the one noticeable change I did …
Just checked and the only service doing VESC repairs in Germany closed down because Vedder licensed his work. Does anyone here in Germany repairs DRV8302 errors ?
I dont notice anything burnt or smelly from the VESC.
Yup, I’ve contacted @zmoney and he immediately offered me to take care of it! really great service. However they are located in the US… didn’t even know as I have gotten this VESC from a forum member
Nice of them to actually offer that especially since you didnt purchase it from them directly.
Yeah, I thought mine was toast aswell, and as you mentioned the german DRV repair is closed…
Considered(consider) getting myself a hotair solder station, some drv chips and futureproof myself abit. Wanna go Foc again but dont dare without any spare parts.
Did yours immediately work after putting it to BLDC again ? And you are not getting the DRV8302 error when running the motor in BLDC ?
Yea that would be great. I don’t know about the learning curve compared to normal soldering tho.
There are some local services here that offer SMD-Soldering and works. But I’ve read that most of the time it is not just the DRV8302 that needs to be replaced. And those guys did not work with VESCS before…
Another thing, I’d like to rule out that my motor is dead too. Is there a way to check up on the motor ? I don’t have any other ESCs lying around. Is it correct that it does absolutely nothing(no stuttering,…) when trying to manually spin it via the arrow keys in the BLDC. It is just cold dead. Is that the way the motor behaves when having a DRV fault ?
Oh wow I did not know that they stopped repairing VESCs. Seems a little off as only the name is trademarked, so I don’t get why they have to stop repairs on already existing hardware. Have you contacted them and asked for an explanation?
I did not try until day after as I was sure it was dead(even smelled burned). Reset default day after, did my motor detect and settings and it worked. Tried it outside aswell as on bench. No errors
Mit sofortiger Wirkung bieten wir keine Services für das VESC Projekt an. Herr Vedder hat sich entschieden „VESC“ als Trademark zu führen und selber kommerziell zu vermarkten.
I had contact with LP Electronics the 27/3, telling him my VESC broke. I created a ticket in his system and got a message telling me to send the VESC which I did the 28/3. Asked him 10 days ago if he received the VESC but I haven’t got a reply yet. I hope he is alright.
He has helped me with three VESC repairs prior to this one. Great service!!
Did not know he was quitting Hope I can get it back if he will not fix it.
Unfortunately I broke my other VESC yesterday… again.
Man, I have killed my two VESCs five times now and only ridden around 50km on my board
Yesterday I ordered two new VESCs… different brand and I improved my HW design around the VESCs to prevent any more failures.
Also ordered a hot air gun station and all the equipment needed so I can start doing my own repairs. This can only be a success haha!
Hey guys, just a quick update on this that might be of interest to you I’ve used the link @XIII posted and I’ve gotten a reply to send them/him the VESC including price details,…
VESC has arrived a week ago and still awaiting an update to the status.
Also the post on the original website is gone. I guess he changed his mind about servicing VESCS Well, good to know there is somebody in your country who can do the work for you.
