So I recently been having troubles with my board and have been spending lots of time trying to fix it.
So right now I have reached an Issue that I can’t solve.
Specs:
120a 6s FVT ESC
5055 280KV motor Torque boards
2x 3s 5000mah batteries running in series
So when I was programming my ESC with a programming card everything was going smooth. I was able to change the settings, The motor would twitch whenever I updated something and looked like there was no problem. However when I tried to test out the motor it wouldn’t work. Normally I would hear the beep confirmation when the motor would turn on although this time no motor beep. My GT2B is connected, ESC just arrived from the mail, Batteries are all balanced, motor seems totally fine and checked all the wires. I have no clue whats wrong.
If anyone could help me it would be awesome thanks
Alright so I tried calibrating it but once i got to part where i wanted me to pick my forward and brake it wouldn’t beep when i pressed the set button.
