hi guys, recently everything that could go wrong with my board has happened and its frustrating. after thinking i sorted everything out my motor wont turn now. ive linked a video showing what i mean. idk what this could be, ive already checked the phase wires and they are not touching. https://www.youtube.com/watch?v=zqWsnc4Dz1s
I think you are using a VESC? Maybe you can see in BLDC tool what the ppm signal is and its behaviour.
i checked the realtime data but the problem is with my computer it cuts almost all of the information off at the bottom and i can resize it to fit
After opening the remote I found this wire disconnected and I think it reconnects right between the white and black one. Torque
boards is this right?It looks like the wire must be connected to that spot and could be your problem. I think this wire goes to a potentiometer? If so it explains why your remote is not responding to throttle.
yup it worked!!!thanks so much
You solved it yourself
Have fun!
