I’m looking to build an all terrain board, and torn between which mounts I should go with.
I will be riding this around the beach a lot, so I think chain drive is a bad idea (rust comes to mind). Dual motor is also a must.
That said, Trampa’s all terrain dual motor setups fit what I’m looking for, but are also $1,100 without even getting esc’s, batteries, a remote, and other misc parts.
I have an Xcarve and would be down to make my own mounts, but where would you guys suggest getting the belts and pulleys if I went that route? My preference is not to fully DIY the entire drive train, i.e. I would rather get gears that fit trampa hubz without me drilling the holes, etc.
thanks all for the input!
@barajabali you were the first to come to mind if you have any thoughts.
also, let me just tell you some regrets I personally have on my mountain board.
Go 12s. do NOT use R-spec 74’s. I would go down to 170kv same ones that nowind uses in his builds. Go with either the ugraded chain kit or the belt drive.
DO use TB ESC’s (i have some left if you want cheap)
