Hi,
Firstly I would like to start that I want to build my own mountainboard.
I have used calculator found on this forum and my top speed should be about 45km/h.
I think that I have thought through my design, but what do I really know?
Basicly I am depending at you! Please give me a feedback and tell me what can go wrong.
The most concerns I have with BMS that it might have less power that I need? One motor have 864W and in peak it can go 2340W. So basicly 24A in normal mode and in peak about 60A.
Does it mean that I need 10s 60A BMS? Or 25A BMS can handle about 60A in peak?
where to start… your battery choice is wrong. Those cells are rated on Mooch test as so-so 4.9A battery. In 6P configuration, your battery could output barely 30A. I don’t even know how much will they sag, but probably very very much. Use samsung 30Q, which is some standard.
which ever bms you get, you can wire it for charge only (you will use anti-spark). in this configuration, bms discharge rate doesn’t matter.
about anti-spark. I would probably buy one with good reputation on forum, instead of random one from aliexpress. you could use loop key too, cheaper and more secure option.
think twice about your battery configuration. 6P in one layer will be about 55cm long. you will have to use wires for series connections, because nickel will break quickly (because every board flexes and that will create forces on nickel in series connection)
flipsky 4.12 is good cheap vesc. for that money you can’t go better.
So from what you wrote I understand that I need to change the cell. Where did you found the information about Mooch test of those batteries?
I’ve found those Samsung 30Q on aliexpress:
You were speaking about them?
About the 6P being too long. I want to mount it on my frame in 3D printed case so that wont be a concern. It will be even longer about 65cm with a case:
So from what you told me about BMS I understand that if I choose 25A BMS It will carry those motors even in the peak load (65A each)? Can you explain why is that?
I can tell you right now that those 30Q cells from aliexpress are fake. Even from photo I can see that positive (+) end has 4 legs, and original has 3.
buy cells from nkon (if you are from EU. if you are from USA, you will have to wait maybe even 2 months for your order from nkon). I know battery might seem extremely expensive when you want to build you first board as cheap as possible, but it is only part that you should do right and not save your money on it. you could always use quality battery in your new build.
if you gonna use printed case, then it is ok to use nickel everywhere. I see you are ready for one really long battery
I am talking about bypassing bms - aka wiring it for discharge only. in one circuit you will have bms and battery - bms has only one purpose here - to balance charge battery. in another circuit you will have only wires from battery + and - to connector to vesc.
or you can use bms for both charge and discharge, but then take at least 60A bms. your 6P 30Q battery will be capable of more than 100A discharge.
@Tinp123 did give some good recommendations already. Can just second that you should stay away from buying cells from AliExpress. It’s not worth the troubles. 30q are 2.49€ at nkon right now and you can be sure they are legit.
Which deck you are using?
Your batter rig is stiff, most mtb decks have a flex, that will not work.
Think about top mount battery. You might not like the look in the beginning, but it’s way more practical.
Skip the antispark switch and go with loopkey.
I have seen too much anti spark switches blow up and a loopkey is super cheap.
If you really want performance I wouldn’t go with 4.xx hw vescs. They heat up quick if you set them up to more than 30A bat max.
Yeah, but my problem is that I don’t have a spot welder and I am looking for preassembled batteries that have nikel strip mounted on. That will alow me to just weld cables with a typical solder. At nkon website I haven’t found any
Buying a spot welder is right now a crazy idea just for making a one battery pack.
You can select the nickel taps on if you check out
In the green box in the down part.
You can also get pre welded packs.
Just ask in the place I linked.
Some battery builder offer that service.
They basically just weld you the p group and you than can solder them up how you want
Okay, from your experience batteries with nickel taps are easy to solder? Does it mean that is safe to solder them together using those preassembled nickel strips?
Because in my mind there is an idea that I will be not doing soldering directly on battery but on that nickel tap and therefore it won’t heat up the cell.
I never bought cells with nickel strips.
I have a spotwelder and do my packs with it.
Wires I solder on I try to solder before I weld the nickel to minimize the heat on the cell.
Nickel will also heat up.
If you have a strong solder iron and use flux you should be able to do a good solder join in a short time without to heat up the nickel and with it the cells too much.
I think that you understood me wrong. I am not seeking for a different solution for ESC or VESC, I believe that in that matter my design is well thought.
My troubles are within me wanting to connect 24V LED strip to 36V battery, so I want to downgrade the Voltage to 24V. Second issue is that I want to mount a simple switch (on/off) and I am asking if a regular switch will be ok? Or I need to look for some parameters?
to get your 24V just use a step down converter which output 24V and can handle the load of your lights.
for the switch it is the same, it need to be able to handle the voltage and the current for your lights.
