Hi,
I decided to start building my mountain board with a single engine configuration, and then adding a second engine in a V2.
Given this, which motor do you recommend me? Size and KV.
Any other advise or recommendation on any other aspect of the construction is more than welcome.
Low kv⌠High battery S, It is hard to give advice on this as all parts are a balancing act together, the classic would be 12s, around 150kv and a RC car esc,⌠but Vesc6? budget? what you doing for a mount? As they say in gaming âŚ
GLHF
30c would be enough?
I do not understand the last part of your comment, my English is very limited.
I would be willing to buy a vesc6, maybe FOCBOX if I had the certainty that it is suitable for what I intend to build.
I understand that my other option is FVT 120 12S - âSleeping Lionâ, will the braking be good?
What inclines me to choose a Vesc is the safety in the braking, so it is important that if I choose another option, it has similar characteristics in the aspect of braking.
At first I do not look for a great acceleration or speed, I will get to that point when I make the V2, if I look for a decent speed, safety in braking and good torque.
Maybe the new 125kV turnigy motor from hobbyking?
It has sensors so great for startup torque.
Sealed so rock canât go inside the motor.
I got the motor right now and itâs very silent, powerful and well built.
I actually donât know anything about those ââ5335ââ-numbers.
I only look to the kv rating, diameter, max amps/power/voltage.
Yeah I have heard about that motor but isnât the kv rating to high?
I would recommend sk3 6374 149kv with 12s. If you can get censored ones, that would be recommended.
Focbox would be sufficient enough but if budget is not an issue, then vesc 6. But then again if budget is not an issue, go dual right away. I did what youâre trying to do, mono drive. It was disappointing, itâs ok if you donât plan to go offroad.
Mostly I want to be able to run on dirty roads, not the mountain, maybe some gravel and dirt (like parks paths). I am almost convinced to choose the Sleeping Lion, it cuts the budget quite well, I also understand that the Vesc have little power for e-mtb.
Do you think the turnigy engines are of better quality than the Tacon?
About budget, i started with the idea of putting whatever Chinese motor to my current longboard, to start on eboards build, and now I want to build a mountainboard, the budget is growing every day, so it is flexible.
Thanks @BoostedBuilder , but I think choosing the most expensive of the most used components is the easy and expensive way, my idea is to look for a good value for money.
