My deck is an EVO copy, with flat truck mount area. 15 inch trucks, flipsky. 6374 flipsky r motors. Flipsky big vesc. Dual. Flex batt enclosure. Fiberglass. 10s5p battery. 7inch AT ish wheels. 15 and 16 pulleys on motor, 66 on wheels. Will be relatively water resistant.
I am disabled, heart failure. I am building board, MOSTLY to run pup. I have a Eglide, 400 watt single that doesnt do the job anymore. Too small tires, too harsh brakes, too weak for hills.
Used to be a plastic injection moldmaker, process eng.
I have to wing it, as I havent been able to get my tools and such from old place, Covid and all.
Board should do 30ish, have GOBS of torque, I will mount heatsink outside enclosure.
Likely will ride, then opt for riptide bushings, when I know how to go. Will get the ceramic 10mm bearings someday. Should be similar to the top DIY builds by pros.
Made the mistake of ordering a batt encl. from Russia. They dont do anything fast. Jonesing for the finish. Build is almost done cept for all the electronics.
