Martin
May 18, 2018, 2:19pm
#1
Machining point
Trampa Skate Truck(Some modifications)
1’st => 10mm cutting aluminum.
2nd => 4 angle machining for fixing HUB motors.
Maytech 9055 HUB Motor(Some modifications)
1’st => Extending inner hole 8mm to 9.5mm
Mounting for temporary testing.
After testing, i will changing with double drop deck.
I will compare HUB motor heating test with gummy tire HUB motor and without gummy tire HUB motor
Front Hub motor is with gummy tire and rear HUB motor is without gummy tire. Because of HUB motor heating test
I will adding block parts between HUB motor and Wheel.
Disassembling for extending inner hole 8mm to 9.5mm
Cutting aluminum around 10mm.
dude that sick, cant wait to hear more
Martin
May 19, 2018, 12:31pm
#3
After first riding, i felt that acceleration is not bad.
I got some problem. Ebay ESC(for brushless motor) is not suitable for HUB motor.
I must change ESC with Ebay 4WD ESC for HUB Motor.
Maxid
May 19, 2018, 4:46pm
#4
Love how you realized the torque transfer between motor and hub - so DIY
Get VESCs - you will end up paying double otherwise. Learn from our mistakes
Are you planning to make a video riding it? It is so creative!
Great idea mate, do you have any dimensions of the Maytech motors stator?
Martin
May 20, 2018, 1:26pm
#7
Please refer to below link.
I will change other deck(double drop deck) at next week.
Martin
May 20, 2018, 1:30pm
#8
I’m using normal HUB Motor(Maytech 9355 60KV).
This HUB Motor stator has 8mm hole for normal longboard truck.
So, i expanded inner hole 8mm to 9.5mm. Because Trampa truck is 9.5mm.
I was meaning that diameter and length of the stator. The part with the wire wrapped around it
Martin
May 21, 2018, 12:21am
#10
I didn’t measure diameter and length of stator.
If i disassemble HUB motor, i will measure that.
Martin
May 22, 2018, 12:56pm
#11
Just idea for installing to Trampa spring turck.
Wheel hub is Trampa 6 hole hub + 3D Printed HUB.
Unfortunately some short.
Naysh
May 22, 2018, 7:32pm
#12
Nice mod man. Seems easy enough to do with basic tools. Did you use Dremel
to modify your hanger? I might give this a try.
Martin
May 23, 2018, 7:18am
#13
A good way to recommend thanks.
If I go ahead, I’ll use the recommended method.
Martin
May 28, 2018, 3:32pm
#14
All parts is arrived.
Now it’s time to finish.
Good tourque
Martin
May 31, 2018, 4:16pm
#15
Completion of ESC mounting for testing.
This conversion seems super practical and could be applied so almost anything. Nice work! You may be onto something here.
Hi, does anyone know can these hub motors handle burst current larger than 22 amps if cooling is not a problem?
