My electric longboard checklist
Hello everybody,
I’m a first time electric longboard builder and I’ve completed my checklist on all the things I’m thinking about buying. I would love your input on these items. here is the list:
battery: 2X in series http://www.hobbyking.com/hobbyking/store/__16227__ZIPPY_Flightmax_8000mAh_5S1P_30C.html
motor: http://www.hobbyking.com/hobbyking/store/__18128__Turnigy_Aerodrive_SK3_6364_245kv_Brushless_Outrunner_Motor.html
trucks: http://www.enertionboards.com/diy-electric-skateboard-kits/mono-drive-mechanical-kit
Controller: http://www.enertionboards.com/electric-skateboard-parts/nano-x-enertion-2-4ghz-controller/
Charger + cables: http://www.hobbyking.com/hobbyking/store/_27079__JST_XH_Parallel_Balance_Lead_5S_250mm_2xJST_XH.html
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=5548
esc: http://www.enertionboards.com/electric-skateboard-parts/vesc-standard/
Deck: http://www.enertionboards.com/electric-skateboard-parts/carbon-fiber-electric-skateboard-deck/
I have one question
Do i have to plug the xt60 connector in the charger together with the JST-XH connector? I hope not, because that would mean I would have to open up the board, take the xt60 connector out and put it in the charger. Instead of just plugging in the JST-XH connector that was already hanging out reading to put in the charger.
Thanks :relaxed:
The enclosure is 28mm deep, your batteries won’t fit, they’re 44mm thick. Make sure you keep that in mind.
You may want to go for a 3X or 4X 3S setup with these
Yes you do, but you can add another xt60 just for charging
I know, I forgot to ask if it was possible to take those lipo batteries appart and space them out. in parts of 2 so it would fit. I know how to soled and i dont think that would be verry difficult. https://www.youtube.com/watch?v=SVMuaDnsqiA do you know if thats possible?
Well i wouldn’t recommend disassembling lipos unless you are very confident and know what you are doing. These things can bite pretty hard and scare the shit out of you.
Also take not that the deck is made out of carbon fiber, so it’s conductive. You need to make sure every thing is well isolated and protected
okay so i’m going for the 3x 3s batteries in series. how do you charge those?
this
is with 2 but how do you charge 3 lipo batteries in series
Well one easy answer is to charge them individually, but have to agree that is long and tedious.
Check out other lipo build threads, i don’t think there’s many 9-10s lipo charging options out there.
But i would config the batteries in a 9S setup and have an adaptative harness for the balance leads and find myself a 10S charger.
Are you from the US or Uk or AU?
Europe, the Netherlands
Oh ok makes sense then cause if you were in US then I would have recommended ordering from DIY best of luck with your build.
