so I could not sell any of the pieces I had to buy a trap board and decided to continue with my longboard and put wheels of 6 or 8 inches I have 3 table options:
mbs all terrain longboard
jetspud
loaded kuth-taka
Regarding wheels, I would like to have two mods all terrain and street. These are my options:
mbs all terrain longboard (for the street) (I live in Mexico the streets are poorly paved)
aliexpres 6x2 with printed pulleys
evolve all terrain conversion kit
These are the parts that you have already bought:
sk3 6374 192kv dual
tb reverse motor mount
44t pulleys for the mbs all terrain longboard wheels
mbs all terrain longboard deck
13t pulley motor
torqueboards 218mm trucks (I plan to extend the hanger to 250mm to fit the two engines) (I have an acquaintance who works with aluminum)
focbox unity
12s2p echo with turnby battery from hobyking (4x6s 3000mah 20c)
So right now you are just wondering about wheels? And you want to be able to switch between 2 different sets: one urethane, one pneumatic?
I’m not sure if you are going to be able to fit 8 inch wheels on a jet spud without having some really long hangars either. (that 250mm may work…I’m not 100% sure)
Each wheel set is going to need a different belt size btw.
With that trucks you want a mountain board where both ends angled upwards or a stupidly crazy wedged riser which should then also work on other longboards.
Just for the thing I am only getting some parts for the sales Also most of our stuff is on material cost and
machine wear not much profit is on because cmon 230$ gear drive TB Dual motor kit cost that much
