Hello, new here just wanting to share my first ever build. You guys have helped me a lot when researching for this project. Pretty happy how it turned out
For drive train I used off the shelf maxfind M6 all-terrain hubmotor kit: Hub Motor KIT and their hobbywing esc
For the battery I wanted to use Bosch powertool batteries for couple off reasons: 1 they are something diffirent and on my opinion cool looking 2 I can use those batteries for working when not riding and 3 easily hot swappable
For electronic enclousore I used small pelican case knock off mounted on top off the board for ground clearance
For lights I first thought about using bicycle lights but didn’t like to recharge those separately so I bought 13-50v → 12v coverter Pololu - 12V, 4.5A Step-Down Voltage Regulator D36V50F12 (so only main battery to worry about), mini led light bar, motorcycle mini tail light (both are super bright and I am happy with them) and on off switch
For the deck I used my old skateboard deck I allready had lying around.
Only thing I am thinking about changing is bushings for bit stiffer ones as on higher speeds it feels bit unstable, but on the other hand I built this board pretty much only for moving around my property (living on countryside so lot of land) so maneuverability is key. I have to think about that. Or maybe if I feel bit crazy maybe 4wd?..
What you guys think about this build?
