Better to spend 100 extra than to loose a motor or ESC, I can say this from experience.
About the temp sensors I don’t know if somebody is working on that. But if the ESC can not cut power to the motor base on the sensor info it will make no difference.
Yeah, there should be some circuit put into place then, to shut down the power… or, if you get the reader on your remote (through microcontroller), then you could just shut off the throttle.
Well, anyways they are out of stock and the only alternative is the Toro 150A.
Btw - I know i will get boring soon, but - did you order yours from China warehouse or Usa one (the motor)? As I am afraid now, that if I order straight from china I will get the ‘‘infamous’’ import tax.
Thanks. For the info back to drawing board me thinks. Looking like a new build … Think it going to be something simple and cheap for first build … Long board trucks single motor mount pulleys wheels and all the bit and bobs u need to start a frist build. Now the hard bit go source and read
Not sure the MBS wheels I have are worth using. Plastics rims. Maybe better going for longboard style skate board Wheels and trucks for first build. From what I am reading for around cities lots of people using MBS wheels … Really no idea I just want a simple E skateboard then move on to better and greater things
