My first build. Single motor. 450 $ Budget
Hi everyone !
I have been doing a lot of research and I finally matched some parts for my eboard. I want ask if everything is OK and please give me any suggestions that you have. Because I know something is not correct in that build. I’m still learning about it. My budget is about 400 - 450 $
I weigh 62 kg (136lbs)
VESC: products/torque-esc-vesc-bldc-electronic-speed-controller
Controller+receiver: https://www.banggood.com/2_4Ghz-Mini-Wireless-Remote-Controller-Receiver-Electric-Skateboard-Longboard-p-1179725.html
Motor: https://hobbyking.com/en_us/turnigy-aerodrive-sk3-6364-213kv-brushless-outrunner-motor.html?___store=en_us
Battery: 2x https://hobbyking.com/en_us/zippy-flightmax-5000mah-4s1p-20c.html
Trucks+bearings: https://www.amazon.com/Caliber-Trucks-Cal-50°-Longboard/dp/B06Y5QCGNX/ref=sr_1_3?s=sporting-goods&ie=UTF8&qid=1507571731&sr=1-3&keywords=caliber%2B2%2Btrucks&th=1&psc=1
Motor mount: (can’t decide) suggest please
Wheels: (can’t decide) suggest please
Deck: (can’t decide) suggest please
I think that’s all. I really appreciate your help and suggestions.
Stay away from those remotes, remotes like that have a really bad rep, I had one and it cut off on me mid rid, I didnt fall and die but I had to push my board for a good 2 miles.
If youre on a budget I would say to try out the hobbyking motor mounts, they seem pretty sturdy and theyre really cheap at less than 10 bucks, I have 4 of them and I havent tried them out yet.
For the deck just get any deck you like really, for wheels get some flywheel clones since youre on a budget and dont forget about the pulleys
Thank you for your reply :slight_smile:
I got a really nice cheap 27" mini cruiser board. which you could put your bigger trucks on and I’m not sure what wheels tho.
Hmm I have a feeling that none of you guys have actually ridden a longboard
Ideally it should be a larger longboard
I have zippy flightmax 4s1p 8000mah 30c and they already sag a hell lot when drawing at a higher rate. Just be aware that you wont be able to climb crazy hills without your voltage indicator dropping by 40%.
Also if you’re gonna build an 8S battery I’d suggest going with a 260kv motor:
Skateshred.com has great prices on decks, griptape and hardware. I went with this deck http://www.skateshred.com/index.php/wholesale-blank-longboard-decks/wholesale-kicktail-longboard-232.html had to use 1/2" risers to work with 90mm wheels. Which they also sell but only in neon green.
Check out this place too http://www.customskateboards.com/Blank-Longboards. $25 for a deck ain’t bad. I’ve been using one of their decks for a year and so far, so good.
I second http://www.customskateboards.com/Blank-Longboards! I have there Blank Free Ride deck.
Unfortunately, I live in Europe :confused:
i got that motor from hk brand new if you want, pm me if interested
