hey fellas!
im new to this sport and want to build an electronic skateboard for daily commute myself.
Please have a fast look over my listed componentes and tell me what doesnt work, im open for any kind of critic!
I want to build a Dual Rear Motor Longboard:
construction: Epoxy and Tri-axle fiberglass sandwich a vert-lam bamboo core
length: 98cm
width: 21.5cm
wheelbase: 94cm
flex: 3 (68-90kg) -> i am 73kg
truck mounting: topmount
Im COMPLETE noob on electronics, i just have figured how to connect everything.
Do you know which deck i shall use?Can you tell me weaknesses of my setup?
I have those motors and their 10s4p pack and highly reccomendation both. Excellent customer service as well. For your first build I’d get some vesc insurance they sell just incase.
More than anything new user error seems to be an issue, from what I’ve read. As a total noob myself, I had no issues setting up my ollin vescs. After reading some how-to threads it was very easy. But it is possible to mess up your own vesc if you input the settings wrong. I’ve also read they’re unstable in FOC mode so I’ve never bothered to try it.
However, a balanced build with correct settings shouldn’t have any problems. I went with a 10s4p battery because it was the most recommended setup for a vesc and 190kv motors. BTW, I’m not an expert on this subject. I actually sent Dexter my shopping cart from his site and asked for his input before I purchased which helped clear up some of my beginner confusion. I recommend reading as much on the forum as you can.
190kv is low for 6v
Better to go 10s with 190kv.
It’s a good combo that will get you 25mph
And good range.
6s 2p will prob only get around 5 miles
10s 3p would likely go 15 miles
It’s well worth the extra cost if you can swing it.
2 of those would be 12s which is too high for 190kv motor with Vesc.
You could get a 10s3p battery pack from Diyelectricskateboads.com
Or you could use 2 5s Lipos.
But if you use Lipos, you’ll need a balance charger and you should stay with a known brand like Turnigy
