Okay so basically i set out to make a better way to keep my lipo chargers. Previously i just had them permanently on a bench but after moving recently I’m short on space
That is the finished results atm. Still needs a usb charging port, voltage indicator and exra 12v ports to hook up more chargers. Also a voltagein so i can power it off a battery if i want
Yea that’s a good idea thanks. normally im only charging 1300mah packs ( racing drone) so it has plenty of room. Anything larger to much larger will only be 1 pack per charger
