what do i need to change? I have a 10s5p made with samsung 30q cells. I also need the brakes to be a little stronger because it takes me 1/2-1/4 of my street block to slow down to a stop NOT at full speed and i keep rolling through stop signs, i weight 215-220 lbs
*Up min battery to -15 to gain brakes(or higher up to -20).
*You could up your battery max amps if you want speed/torque increase (assuming you are dual I didnt look into what you are working with, sorry) to 50 amps each vesc as with that 10s5p pack you should be good to 100 amps (5 X 20[‘max’ discharge of a single 30q).
*Limit Max ERMP to 60,000
*Uncheck limit ERMP on negative torque.
Dont listen to me though, wait til someone more experienced confirms this or sees other shit. I am just trying to learn also by helping.
okay so im about to upload my settings using Ack’s tool and i noticed what u said in another post about the ramp up @chaka and i changed that but mine isnt when i floor it from a dead stop (i dont do that as a general rule of thumb) but whats going on is when i am cruising i have to keep throttle at 50% on my remote otherwise it will start shuddering, not like the motor losing sync but more like someone turning the power on and off and it only happns when my pack hits 50% or lower… its unridable past 50% charge on a 10s5p pack with samsung 30q cells
and another thing, it only happens when im on the board, if i lift the board off the ground or turn it upside downa nd ramp it up to full throttle it can sustain it no problems
ok so i strapped my laptop to the board (its a little netbook) and did the real time data (not sure f this helps) but this is the readout from when it drops and then tries to ramp up again and then i hit the brakes.
its in BLDC mode sensored since i have 4.12 hardware (not upgraded) and this only happens when i hit 50% or lower charge… from 100%-51% its fine and i can cruise full throttle no issues
oh and my setup is a single 6374 motor (until i buy a new motor or repair the one i dented… need a bar magnet for the can)
