Name of the 11 pins on the Enertion Spacecell
Hey :grinning: What the name of the 11 pins on the space cell and where can I buy both male and female version?
Thank you for your help.
15384301402192097489355988140372
The photo doesn’t work, but it might be a “JST connector” but there are different pitches available
Thanks Do you know the pitches, if not how can I found out.
digital calipers or a tape measure
Jst XH 11pin, digikey, mouser…
Usually those connectors are jst ph with 2mm pitch. @blasto you sure they are xh? Just checking to be sure.
If it is then bleh since every connector on the focbox is a ph.
On second thought it might just be xh since I think this other china bms I use is indeed a different size then my bestech bms which uses the what I consider standard ph connector.
You could always just ask enertion 24/7 support.
Yes i am sure, the pitch is 2.5mm
