Hi everyone. I’ve got a full enertion setup board which running a nano-x remore with no issue for nearly one and a half year.
Since I got the nano-x remote,I was using twin vescs and it always bound instantaneously. Blew a vesc one day and got a replacement focbox, ran that foxbox as the master and the vesc as slave then I encountered the problem which it wouldn’t bind. Swapped the vesc as master then well all good.
A couple of months later the vesc blew itself up so I got another replacement focbox and I set the new focbox as master and everything worked just perfect until today… For the problem now I have, I’ve searched almost every thread online and tried everything. Somehow none of them work.
Tried reconnect the servo while the board battery is on and the remote power is on, it works. But who wants opening the enclosure every single time before go for a ride? Tried get rid of the tape behind the servo, tried putting a bit solder on ch1 pins making them thicker and swapped both focbox make sure their wires are fine. Tried relocating the servo far away from focbox but it just didn’t work. Also enertion support says that it’s out of warranty so won’t send me a new one.
Now, I’m thinking buying a 2.4g mini remote from ebay just for the servo but don’t know it’s gonna work or not. Anyone got any good idea for getting this issue fixed? Much appreciated!
