Nano-x yet another problem
Hello. i just received my nano x and so far i cannot make it bind properly… i read all posts on forum about the tape in the reciever about the signal wire… tried everything
so far i cannot make it bind every time. i connected the reciever to 5v and it worked just fine … some somewhere else should be the problem…
Any idea what could i try to make it bind every time ? Thank you.
if i play with the wire it will bind from time to time… but im sure the wires are good cause i changed 5 wires so far and all do just the same.
also i tought might be a problem with wire connectors so i soldered but still same result…
I have the same issue as you. But somehow I got them to work now.
