Been compiling a list of questions as im researching and learning the last bits of info before i decide to build this 12s8p battery/board. Any help is very appreciated.
Heres a googlesheets link to the parts i’m talking about with their product links.
- not sure which BMS to get all the options are overwhelming I landed on this- 11S 12S 13S 14S 15S 36V 48V 58.8V 60V smart BMS with Bluetooth function UART communication 20A to 60A constant current – LLT POWER ELECTRONIC
Which has only C- and B- ports. In this tutorial i’m following, P- is wired to the charge port, and B- wired from the negative battery lead , leaving -C unused.
Heres a drawing I made to help visualize everything better - https://imgur.com/a/nICGNsI
this part has been messing me up and i cant understand it, makes me want to buy the mboard bms and call it a day; but i want the bluetooth function to be able to monitor cells like im used to on a lacroix.
Whats the process like for wiring front headlights to run off the boards battery? I have the lights and connectors. And if i wanted to add an LED screen battery indicator, adding these things are fascinating but i have no idea how its put together.
Will be using a SF12 connector for the charging port and on the receiving end of the WATE charger. My question is i can safely solder on that new connector?
The different flux deck/enclosure options is confusing me, im leaning for the “Flux AT DIY Kit” with the new deck design, but some builds ive seen are done on the old shiny style enclosure. the DIY kit also has all the holes and heatsink i need for the stormcore. Need some guidance lol i cant afford to buy the wrong stuff at these price points
Just laying out my plans, need to hear if i’m doing something wrong. Might have more to add but my notepad is getting unorganized. Thanks.
