I have another question. This is also Lipo related. I’m creating a battery box and want to install a led push power button. But they are rated for 12v and I will be putting in four 6000mah 6s lipos. Also putting 2 series connector so I then will have two 12s lipos.
So my question is, do I need a voltage regulator to down the power so i don’t burn up the led power button? If so, have any links for one?
How much power will be flowing through the button? It is just to turn on a BMS or e-switch, or are you intending to draw a significant amount of power?
If you will use it an on/off switch, you should just use a xt90(s) loop key, but If you abselutely need a high tech button Go for the vedder anti spark seith
Thanks louwii! I’m just not sure which one to get, lol. I will be running two 60xx 118kv motors with four 6000 6s lipos (two in series, so it will be two 12s lipos)
