Need advice on first build
Hi everyone!
Thanks for everyone who answered questions in my previous thread. It really helped me today when I was deciding on parts.
Deck: Bamboo Longboard
Trucks and Wheels: 83mm Wheels with 180mm trucks
Motor Mount: Built myself (Advice from those who have done this with CNC mills or whatever is greatly appreciated)
Drive Train 38 Teeth Large Pulley 14 Teeth Small Pulley 60 Teeth Belt
Motor SK3_6354_260kv Brushless Outrunner Motor (Alternatives welcome. These are currently in backorder =/)
ESC I could really use someone’s help between deciding between this Turnigy one and this HobbyKing YEP one
Remote
Bluetooth Arduino (Also wouldn’t mind someone who’s hooked up their phone to this)
Batteries 3 x 3S LiPo Batteries
Enclosure Not quite sure yet, but probably just a walmart box
Charger and Power Supply I would also love some help as to which chargers to get and how to hook it up. People keep talking about “balance charging”, but I’m rather clueless to what that means and how I can set that up.
Thanks, Harnek
You may want to get a larger motor (perhaps 6372) if you’re going single drive for the additional power for hills. Balance charging is the process of balancing out your cells while charging. The Imax B6 is a pretty popular lipo balance charger. You’ll want to balance charge to avoid overcharging certain cells in a series.
I agree, I use the Imax B6 V2 and it’s great. With the V2 you don’t need a power supply, just plug it into the wall.
If you want to learn about how balance chargers work and why you should use them, check this video out.
I think your motor has a high KV rating and will result in a high top speed when running on 9S. (calculated with this) I would say go for a lower kv motor to get more torque, maybe 200 or 220. These motors from chaka seems nice, haven’t tried them yet but they should do wonders. The r-spec motors from enertion is also a beast.
If your budget is over $100 for an ESC I would say go for a tested ESC like torqueboards. Remember to pick a programming card if you want to tweak the settings! If you are really interested in tweaking with your ESC you could get a VESC but it might be over your budget.
I think the tested ESC one doesn’t handle higher voltages tho, right? the VESC was a little too pricey for my budget =/ and the VESC on enertion boards won’t be coming in until Julyish, so I’m kinda hesitant.
Oh right you were running 3 x 3S, I updated the link to the right one, check it out.
I have a very similar build
The mount was pretty difficult to get just right considering how expensive CNC can be. When welding the mount it is difficult on those trucks to get perfectly square because they aren’t cylindrical and they are tapered.
For the ESC, honestly just get the VESC I tried the chinese RC Car ESCs but if your going to spend the money just get the one that is made for eboards.
How was the board you used? Also, you said you 3-D printed the belt, but did you also do the same with the pulleys?
Also, one question about chargers, @karma Say I use a 10S4P battery. Although the V2 power supply says I can only go up until 6S, because each cell is around 2.5S and I plan on charging it in parallel, will it still function?
Thanks, Harnek
Board is great, one or two of the plys isn’t bamboo so it has some stiffness, but it flexes a bit under my weight (245 lbs). I 3D printed the drive gear because I couldn’t for the life of me drill the holes perfectly centered to make a metal one. ABS gears work great no visible wear as of now. The motor gear is metal, and the belt is from that website you are looking at pullies from. Honestly you can save money by buying the smaller pulley and belt on ebay.
Since I assume that you are going to connect the batteries with 4mm bullet connectors and not solder/weld the packs together you can charge them separately. Watch this video for charging a LiPo battery with the Imax B6. You can also parallell charge the batteries with a paraboard if the batteries have the same capacity & cell count. Hope this makes sense.
