I need the esk8 gods advice for 6wd. I lost a street drag to a GXR.
Dualee rear sounds strange, but have you seent it? Have you ridden it?
I’d kinda like to try a quad rear (plus two front obvi), hear me out. Think typical rear dual, rear facing, than add another dual rear, but front facing.
Should I just suck it up and buy another two vesc6 and put them up front too and get big motors?
What if you put 4 drive wheels on one axle? Or put pulleys on the inside and outside of each of the two back wheels? So each wheel had two pulleys and two motors…
I’m not really sure here… did you lost again a GTX or a GTR…
Because the solution could be different depending on the outcome… for one I would say to change the motor gear, for the other one to put a twin turbo v6 on your board…
