Im currently running a dual chain drive setup on a diy mountainboard build. Im currently waiting for some new Lipo’s as the others weren’t great so am changing. Im also considering changing the motors and wanted some thoughts.
Sensored vs unsensored
Small vs bigger
Low kV vs higher kV
Why you want to change and what’s your thoughts behind?
Both would work for a specific goal you wanna reach.
want to get a bit more speed mostly really, bit more of a kick to the board.
One of the biggest differences which is not something im too familiar with is the Internal resistance ad on the SK3 is only 0.016 Ohm compared to my current motors being 90.
Im assuming by hanger you mean motor mount? If so, its a custom build so i will make the mounts fit the motor, its the space between them i have the issue with
Ill always recommend maytechs.
@hyperIon1 has been cutting some great deals lately.
Tb has quality parts and they are here on the fourm regularly. So if any problems do arises you know you’re taking to a rear person.
Message @hyperIon1 he’s been clearing out stock and smelling things lower than normal.
If he doesn’t have anything that works post a WTB thread. Never know what people have laying around.
What’s you max budget for a pair?
