Hello,
I’m trying to build an electric skateboard, I would like it to go around 35kph.
I already have some parts:
The trucks with motor mount and pully, its a 39T, to fit some abec style wheels
I also already have some lipos laying around:
4x 3s 3000mah lipos which I’m planning to put in series to get a 12s battery, and 2 more 5000mah 3s batteries
A 6374 192 kv motor (turnigy sk3)
Now my question is what wheels should i get?
Im thinking of going for 83mm wheels to get some more tork, because i probably will have enough speed with a 12s battery.
Or should i go with 90 of 97mm wheels and maybe just go 6s and put my batteries in parallel to get more range?
According to http://calc.esk8.it i would get over 50kph with 12s battery and around 30 with 6s (and 90mm wheels) but I’m not sure of this is correct.
So those were my questions, the battery size doesn’t really matter (12s or 6s) because i could test it when I’m riding but its mostly the wheels l’m not sure about.
Thanks,
Would i have enough tork with 97mm wheels or should i go with 90mm? I don’t really have any hills where i live but i would like to go get over some bridges.
I don’t really have anything build yet, but here is a picture of the parts i have
Okey thank you, still not sure if i should go 90 or 97mm wheels, it wil probably be some abec clones as i don’t have the largest budget. I do have a 3d printer tho so i could 3d print a larger pulley but I’m not sure how good that would turn out.
Yeh i thought so, I’m from Belgium so thats probably not going to work. Ive been looking around for a couple of months now but there aren’t many people around that have large abec style wheels laying around. But thanks for the offer.
