hi there i just finish my mountain board today (new motor mountings )
i need some help to set my vesc 4.12 to the best value to reduce heat so here my set up
14 teeth to motor and 48 for my 8inch wheel (yes l know i can use 10 teeth but i want to keep some top speed )
6s 2x 16ah 15c
2x sk3 192kv
4.12 vesc with 2.18 firmware
ppm remote and bluetooth with app
To keep things simple i just need the minimum information to have a safe ride experience with good brake and smooth acceleration and reduce chance of overheat my esc , some talk about erpm max , but at 6s i dont think its a problem to set it at lower value , also i have tried the traction control but it doesnt seem to work with 6s because of less power at the wheel but here i have snow and if this feature can help me to limit the spinning it will be great to use it thanks everyone
motor max 60a
motor min 60a
batt max 60a
batt min 10a
absolute max 130
sorry my weak english , i can also try to upload screenshot thanks
That would be too slow for my taste, at 6s you will have a top speed of 38km/hr my bet is the performance will wear out pretty fast on you and will leave you wanting for more with a subpar esk8 experience.
I’d get at least an 8S to 51km/hr and much wider powerband.
You are going to be runing only 22.2V nominal and 25.2V at full charge, I’m not sure if your battery could handle 60A of discharge for each vesc
yes you right!!! but if it can help reduce the amps draw it will solve heat problem too
but if i need to find in the bldc app a feature reduce my top speed to 25mph
please anyone?
You shold be using the 10t for a better reduction ratio… 192kv * 44.4v = 8524 rpm’s at the motor.
8524/4.8 = 1775 rpm’s at the wheel.
200mm * 3.14= 628mm per revolution of the wheel.
628mm* 1775= 1 114 700 Mm per minute
1 114 700Mm\1000= 1114 m per minute.
1114m\60= 18.56 m per sec
18.56*3.6= 66 km per hour.
Now, this will roughtly be your top speed with a erpm of 59 668…
Now, since 66km/h will be your top speed, we say that is 100%…
25kmh/66kmh= 37%
59668/100*37= 22000…
And there you go! Limit your erpm to 22000, but make sure to uncheck «limit with negative torque», and you should not reach more than 25 km/h.
However, it would be more efficient to have lower kv motors, but oh well.
lol not problem the calculation are for 10 tooth or can be use with the 14 tooth as well ? I found also on my android app a speed limiter but did’nt try for now , my present project is build traction edge with some cutting tire and stud for the winter condition here , l think i will post a some picture about this soon so thanks for the help
Frederik
