If anyone could help me source components that would be great. The type of board I am going for is a single belt driven motor and hoping for li-ion battery but might have to go lipo.
This is the deck I already bought, it has a wheelbase of about 26" which I think should be plenty.
My current plan is to grab a pair of caliber II trucks, orangatang kegel 80mm wheels, riser pads, bearings, a brushless motor, the mounts pulleys and belt, an esc with remote controller, battery and then probably wire connectors where necessary. After all that probably an enclosure also.
Firstly I want to make sure Iāve covered all the components I will need for the board to work. Then I want to find the right compatible components, I know this is a large ask but my main focus is getting a good battery, an esc that works and a motor that works and the rest I can probably handle. The biggest problem with this is a Ā£200-400 budget.
Hey man, you can check out my build thread and I managed to do it for about 500 without the deck, but you could find a cheap one on ebay. Is it for your GCSEs?
Itās for an AS not gcse but essentially the same. Also, I looked over your build thread, good job. How did you find the self made battery pack. Was it cost effective and did it perform? Was it easy to do?
Thanks dudeš. I found it cost effective. The batteries came to Ā£110 the BMS was Ā£55 plus miscellaneous things like Nickel stop and cable. The battery came to a total of just under Ā£200 and I believe a similar premade 10s3p 30q would be closer to Ā£300. After a lot of research and videos explaining soldering technique I found it relatively easy, with only small soldering experience (nothing like the complexity of this) It was just quite time consuming but may be good to detail in your AS that you built the battery?
