Can anyone please help me, I’ve had a day of reading manuals, checking connections and scrolling topics on here but I cannot figure out why my motor still won’t run. I’m running a Turnigy 6364 190kv motor with a x-car 150a ESC from hobby king and 2 zippy 3ah 5c in series.
Get a vesc
any ideas for what I’ve already got? have i missed something simple with numbers here?
photos help champ
Did you calibrate the throttle by holding the set butting while turning it on? I had this ESC and it is very picky with neutral PPM signal which is required to hear the beeps of initialization. After the beeps the motor will work. You should get 5 short and 1 long beep when it is on. If you are not getting them, the calibration is incorrect.
I think the first one is brakes, you get a long beep, then acceleration, you get two beeps, the final one is neutral, you get three beeps. Restart the ESC and it will be calibrated.
The manual will help more.
Wait a fucking minute. 10S?
It’s dead. If you turned the ESC on, it’s dead as fuck. 6S max.
Get a VESC for 10S.
Fuck, I thought 2 ~ 6s meant 2 x 6s I did initially try it with one battery and got a light but no beeps
It’s 2 TO 6S. Try to connect to the single 5S. Does it still have fanspin and LEDs? If it is still alive, you will need to use the 5S in parallel to get a 5S 40C 6Ah battery.
yeah, fan and led still come on
It’s still alive. Connect it to a single 5S, connect your receiver, calibrate the throttle and pray.
I used it with 6S (two 3S 5Ah 20C zippies) and it was quite nice with a single 6365(6364?) at 245kV.
nothing, it all seems to go well but absolutely nothing from the motor
Does it beep 5 times when you turn it on? Did you calibrate the throttle response?
no beeps at all, and I’ve binded the controller again but still nothing
Not binding, throttle calibration. You hold the set button, you turn it on while holding the button. It will enter calibration mode. Make sure your remote is on. When it is on, start holding brakes until you hear one beep. Then you will see the LED change color, start holding max acceleration, it will beep twice. After that release the throttle to neutral and wait for it to beep three times. Turn off the ESC and turn it back on. Hear 5 beeps (4 short and 1 long) and if it is still alive, it should spin.
It’s in the manual:
No need to set to REV. Just do brakes where it is throttle and throttle where there are brakes. My post above is how I did it.
thank you it is working and spinning, just need to get it calibrated correctly now
thanks a lot buddy
Glad to help.
Please do not attempt 10S now. Ofc you can, for science, but last time I checked it is not really rated for it on the inside.
yeah ill try to avoid that thanks for your help
Either use the 5S batteries, or grab like, 4 of 3S 5Ah zippy lipos. Make a 6S2P pack and you will be happy. At least I was. My first build was pretty much what you have.
