Hi im building myself an Electric mountain board and wanted some advice on my build and see if anyone could help me pick out a better battery and options… here is where im at rn
Vesc6
Torque motor 6374 190kv some 3000 watts
2x 6s zippy compact 5600mAh 60c i think
and everything in the kit that isn’t listed above
Look the kit comes with two mounts and two motors of your choice (and also 2x vesc 6). I’m not quite sure you understand that, otherwise i don’t understand why you would buy a whole kit and then switch to other hardware.
Anyways speed calculation can be found on the trampa website or by using a calculator lake calc.esk8.today.
I think the batteries are ok if you are fine with the capacity, but the 190kv 6374 motor might a bit high kv depending on your gearing.
