Hey there, I am a 23 year old student trying to build my second diy e-board. My first build was a plug and play meepo like board. I ordered the parts in china from diy eboard.com and it actually works fine for the price but I´m trying to build a new custom one with a lot more power and range for my little brother. I red a lot of stuff online (especially here, love this forum!) since November last year and I think I am up for the task. The budget for the board should be around 800€ it should have a lot of Torque and Range and be comfortable and nice to ride. I still got some questions and some unsecurities.
First my part list so far:
2 Motors I am trying to save a bit of money on all the stuff from diyeboard.com http://www.diyeboard.com/180kv-n6354-outrunner-motor-2000w-for-diy-electric-skateboard-p-540.html
Pulley for the Motor: http://www.diyeboard.com/dual-35t-to13t-5m-drive-wheel-and-motor-pulley-kit-with-2-belts-p-634.html
Motor mount: https:///collections/motor-mount-parts/products/v4-motor-mount-only
The battery: http://www.diyeboard.com/10s5p-18650-lithium-battery-pack-36v-10ah-360wh-p-460.html
ESC:
alternative: http://www.diyeboard.com/upgraded-v21-dual-belt-motor-sine-wave-foc-esc-speed-controller-p-599.html
Remote:
As for the Deck I was thinking about a loaded vanguard:
For the trucks Caliber II seem to work fine with it but was also thinking about the TorqueBoards: Torqueboard trucks: https:///collections/longboard-trucks/products/torqueboards-218mm-trucks
Wheels: https://orangatangwheels.com/caguama-85mm
Now for my questions:
Is the Flex of the board compatible with the battery or does it hit the ground?
Is the Battery good? Are there any Alternatives?
I recently looked at the 12s4p torqueboards battery and it has a way higher Wh rating. Why?
Is the Motor any good? If not are there alternatives?
Is the ESC good? Compatible with the rest? Good alternatives?
Would the whole build be compatible with mtb tires similar to the Evolve? (of course with new pulley set)
Is the Controller good?
Does the Motor fit to the trucks?
Which Trucks would you recommend?
And does the Motor mount work with the caliber and Motor?
Thank you all for your answers!
