If someone could let me know what I did wrong. Thx
Way too scared to even plug in now
Probably an internal short, or something is connected backwards
Which parts have you used before?
I got all the wires right u think xt60s are too small for 240 amps
My parts are 150A esc 720A burst current. 2 4000 mah 60c 22.2v 6s lipos
By a factor of 4 but they would melt before blackening. That’s the mark of a short
You should test your controller, it may be dead now it has shorted
It looks like either a short or you plugged it in backwards using that harness you have there
Thank God, I tested it its fine both Battery and controller
60x4=240
60 because 60c, 4 because 4000 mah.
So 1c would be 4 amps and 60x4 is 240
So 240A
It’s fine I already gave up on my build everything blew, lol
Yah I mean his math is right, most manufacturers over rate their lipo cells though
I wonder why it fryed everything tho the esc was ment to handle 720A of burst current I was only giving it 240A since I connected the batteries in series and it blew right when I switched the power switch on the esc so it was only like 1 second of 240A
That’s not really how that works. It wouldn’t have been drawing very much current at all. It’s probably because you had no anti-spark switch. The voltage and subsequent amps then rushed through that tiny connector
You made two posts for the same Problem… why?
Wait, what? 12s on an esc? I don’t know which esc exactly you are using, but most of them wir with 6-8s max. I would double check that.
Also this
Where are the mods in this forum???
Ya I think that was my problem lol
12s on 6s esc, I just thought it would still recognize it as a 6s, sheesh just watched a guy for it on YouTube and it worked fine
12S is good for 60V esc like the fukbox
