Need help, what do you think about my first build?
hi,
i’m doing a checklist of my first eboard and i’ve some questions.
specs
R-SPEC Motor + Mount + wheels + torque + trucks http://www.enertionboards.com/diy-electric-skateboard-kits/enertion-single-motor-mount-pro-kit/
deck http://www.ebay.es/itm/pro-tec-Skate-Longboard-104x23cm-DROP-THROUGH-Tabla-Completa-Calavera-/351728659499
2x batteries RC Turnigy 5000mAh 3S 20C Lipo Pack http://www.ebay.es/itm/RC-Turnigy-5000mAh-3S-20C-Lipo-Pack-/231812428502?hash=item35f918f2d6:g:OTcAAOSwT~9WlfsK
controller + receptor SODIAL Flysky FS-GT2B 2.4G 3CH
balance charger IMAX B6 http://www.ebay.es/itm/Cargador-Balanceador-IMAX-B6-de-Baterias-Li-Ion-Lipo-NiMh-Transformador-4091b-/251928655160?hash=item3aa81e3538:g:FdEAAOSwwE5WagD0
vesc http://www.enertionboards.com/electric-skateboard-parts/vesc-standard/
can you give me some advice…
1- i find out that the batteries can have different charges plugs like JST-XH, XT90… which is better for my specs? any of these is better to prevent sparks?
2- i read thats better to connect the batteries in series, if i get a battery with JST-XH charge plug this cable is compatible? http://www.ebay.es/itm/262230784059?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
3- which is the best switch on-off compatible with my vesc under $50 ? or i can avoid this part and plug in-out the batteries?
4- which cable i need to connect the motor with the vesc?
5- do you recommend this battery indicator for my specs? http://www.ebay.es/itm/12V-Lead-acid-Lithium-LiPo-Battery-Power-Capacity-LCD-Indicator-Tester-Voltmeter-/311498010755
thank you!
I recommend getting just the deck, I believe you bought the complete.
You can use an xt90s loop key as an on/off switch, they are about $10 + soldering
It’s going to spark no matter what header you use. You can use these for your anti spark loop. Radio Control Planes, Drones, Cars, FPV, Quadcopters and more - Hobbyking
2- i read thats better to connect the batteries in series, if i get a battery with JST-XH charge >plug this cable is compatible?
That’s a bullet connector, not JST-XH. JST-XH is normally what is used for balance charging (comes with the battery packs you listed). Your packs come with a bullet connector header so it should work. You’ll want to make sure your VESC has bullet connectors as well.
3- which is the best switch on-off compatible with my vesc under $50 ? or i can avoid this >part and plug in-out the batteries?
Building an anti-spark loop as mentioned above. See more here: How-To: Anti-Spark XT-90S Loop Key - ESK8 Electronics - Electric Skateboard Builders Forum | Learn How to Build your own E-board Otherwise you can solder on an on/off anti-spark switch.
Just make sure the motor has the same leads as the VESC (5.5mm bullet connector)
That wont work since max voltage is 12v and you’ll be running 22.2v (2 x 3s = 6s). Try this one http://www.ebay.com/itm/172143986261?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
