Your voltage will determine your speed.
Your nominal amp will determine your range.
Your maximum current ( amp output ) will determine your acceleration.
Thats a simplified explanations from my understanding.
Yeah, ive might have been a bit unclear in my text sorry,
Those things i undernstand, what are your thoughts about building a 10s2p with 30Q or the same pack with 30T?
Will i get alot better breaking with the 30T or will de 30Q be good enough?
so the peak pulse current would be 40 amps < 5 sec, that would mean i could pull 80 amps for a short time and lets say that my motor would be rated for max 80 amps… do you think im having to small of a margin and would i have problems with overheating?
Im turning to you guys since i dont have any experience with this
No 6355 will be rated for 80A, the best (MayTech and their equivalents) are 65A max
Go look at the data sheets for all the cells but 30Q will do 20A continuous and 25R will to 30A continuous…you can burst at 1.5x continuous in general, 3p 30Q or 2p 25R will have similar performance
If it’s a campus board then 10s2p 30Q will be enough…you don’t need all that power. I am running dual cheap 350W hubs on a 10s2p of fake 30Q cells and it’s definitely enough to get around…I get about 8 miles in each day and charge it every night
Don’t get 25R…but VTC5 is a good option if you want hella startup torque
VTC5A are rated at 35A, or 25A conservatively and sag is considerably less than 30Q even, with capacity and cycle life better than 25R. 25Rs sag a TON more than even 30Q let alone VTC5A with less capacity than any of them. I got my VTC5As from nkon for $3.60 a cell after taking shipping into account.
Im not an extremly experienced longboard rider, i just want to have a nice smooth board that have the power! If you look at my project topic you can see what my plans are, i wanted to build a dual drive but since i dont have that money now i might just add another motor later
Look at prices then. 25R cells aren’t horrible. If you find they are significantly cheaper for you, they aren’t a bad option, especially if your going to pay over double for 30Q for example.
