I’m building a new board with the following specs, and need to figure out how many amps I’m going to be pulling, so I can build my battery accordingly.
4wd street board:
- 12s8p molicel p42a @ 240~320a total continuous, could go higher for instantaneous. Bms only for charging.
- 2x dual flipsky esc 6.6+
- 4x flipsky 6374 190kv
- 16t/40t with 120mm cloudwheels
Vesc settings: (still undecided)
- 80a battery amps (each) 320a total
- 80-100a motor amps (each) 320-400a total
I want to figure out how many amps I’ll be pulling from the battery when I ride, both average and peak amps when I ride on a smooth flat ground and on a steep hill. I need this data to figure out how many nickel strip to put per connection. Any help is appreciated, feel free to ask any other questions about the build, or any comments. I will be posting progress on my instagram @schaeo if anyone cares.
