Hello there! I have a quite flexy deck (loaded dervish flex 2). I am planning a build that will require a full enclosure on the bottom so the flex is really bad for that. I was thinking of putting carbon fiber on the underside to make it more stiff.
I need advice on how many layers i will need (say on 200g/m2 CF) to make i stiff. Or if you think that i should use glass fiber instead.
Thanks!
