Just started assembling the trucks and the motor mount after receiving the parts yesterday. With the motor, I can’t seem to figure out where to put the circlip on my motor (probably a noob issue haha). Are the two set screws on the motor pulley and the keyway sufficient to prevent the pulley from slipping?
@luckyfungxd
The circlip goes at the very base of the shaft sticking out of the motor. There are going to be one or two washers between the circlip and the motor. Both of those washers are visible in the photo you uploaded, but I’m curious why they circlip wasn’t already installed. You do not want to run that motor without the circlip
The TB motor shaft has a collar made on it. It replaces the circlip after the bearing. Unfortunately this collar also prevents the pulley from going closer to the motor.
So is the circlip not necessary since the collar is in place? I did realise that I wasn’t able to push the pulley closer to the motor unlike other people I’ve seen assembling their motors.
Nah it was just sitting at the top of the collar where the shaft begins. It’s not clipped on or anything, it’s just there pretty loosely as you can see.
Directly after the motor bearing that you can see in your picture you need to have that little brass looking washer, followed by the circlip. That spacer and the clip keep the whole motor together. Contact @torqueboards for any questions about their products, their customer service is great
The cir-clip on the bearing needs to stay there. I would not remove that. It holds the motor shaft to the stator.
You can use the circlip by the keyway the one closest to the motor to prevent the pulley from going towards the motor mount. But it’s not needed. I typically only use M4 socket cap bolts with my motor pulley only. You end up restricting your range of alignment if you use the cir-clips on the motor shaft. It’s actually been removed in our motors currently in production since it seems to confuse people more so.
