well either motor will be fine. you can run 6s or 10s on either one. Obviously 10s will get you going a lot faster but if you want to hit 23 mph 6s on the 213kv on a 16:36 ratio will do you just fine. Youre light so you dont need much reduction.
Ok perfect thanks i think the 6s will do although i do want the 10s due to the speed they are just to expensive and have too little mAh for their price. What does the ratio you mentioned mean exactly? Gearing?
Well the higher voltage you go. The more expensive things get.
If you’re using the 120 amp FVT car esc then 6s is your max. If this is your first build I’d stick to 6s and you can judge for yourself where you want to go from there in the future.
The gearing ratio is a 36 T (tooth) whee pulley and a 16t (tooth) motor drive pulley.
Just buy this kit
It’s got everything you need in terms of that product/single-bolt-on-motor-mount-with-drive-wheel-kit/
You’ll need some caliber trucks and some abec clone 83mm wheels.
I got trucks deck and wheels so im good with that i hope paris trucks will work. What is the difference between esc and vesc because i was looking at enertions vesc.
okay if and when you order from @torqueboards make sure you buy the paris truck adapter and not the caliber one. and an ESC is an Electronic Speed Control. A V-ESC is Vedders- Electronic Speed Control. it is a custom E-board ESC as oppsed to other ESC’s which are designed mostly for cars.
do a simple search in the search bar for VESC youll find a lot of info
yea Enertion is a great place to buy from too. since youre doing a single motor setup. 12mm is going to be better than 9mm for power transfer. That exact link you sent me is perfect for what you need. but you still need a motor mount, and im pretty sure Enertion doesnt sell a mount for paris trucks. so that youll need to buy from diyelectricskateboard. you can buy the mount alone without the pulleys. I also have a spare Paris bolt on mount in black that i can sell you.
As i add more kv to this calculator i get a higher speed so im thinking of moving up Kv because more speed and its cheaper but somehow i think this isnt a great option. And obviously when i move to 10s the speed increases greatly. But i am reconsidering motor Kv.
