Need help with TorqueBoards nano remote controller
Hi there,
I have recieved all my parts for building an electric skateboard and put everything together. But when i tried to make ik work the controller doesn’t work. I have tried almost everything. I watched the videos from torqueboardds how to setup the vesc and controller. I don’t know what i am doing wrong. Could someone please help me?
can you post a video of your binding process? are you sure you have configured the ESC to use PPM?
hier is the video
your missing some step… maybe this video will show you the wright way. :wink:
http://www.electric-skateboard.builders/t/vesc-faq-setting-up-receiver-and-brakes/244
Hey Johnny thank you so much but sadly enough it doesn’t work for me. I just don’t know what the problem is.
Did you connect your receiver in the ch2
Edit: from your video, you still look like your connect in the bind channel
I believe it should be Channel 1 for throttle, on the Nano. If I remember correctly.
Yep, your right I Think… I’m so use to the GT2B and Mini :laughing:
thank you guys so much it finally works (it should be on channel 1)
