Hi everybody. Some things in my life have been going good, many of the bad things have been staying bad, and now I’m on the other side of the country and my complete dog fucking shit $2000 MSI Laptop that hasn’t wanted to do shit from day one because of its jank ass software finally decided it wanted to kill its jank ass self, and did just that. The hinge self destructed itself on a normal opening, despite me babying the piece of shit it’s entire life.
That being said, I’m only really going to have my phone to do some research, and being used to having a triple monitor setup… a 5.25’x2’ish screen ain’t gonna be great. My apologies if formatting is trash, will try to edit and fix things as I go.
For anybody who will selflessly give their time to help me get a board up and running, it will be greatly appreciated.
On to actual board/questions
So far, I have in hand:
_FOCBOX UNITY
_2x MAYYECH 6374 170KV
Things I will soon have in hand:
_HAYA HB83 SHORTBOARD
Purchases I will soon make:
_TORQUE BOARDS 110MM
_2x keyway
Things I know I should need:
_remote - alien power systems until new Hoyt
_Grip tape/glass frit
_5.5mm bullet connectors to make unity adapters
_Winfly/NESE compression packs and associated hardware
_Trucks - probably surfrodz rkp
_Extension brackets - gbombs, or I might Uber to @Boardnamics, incapacitate him, and kidnap his router (yer using a CNC router right, not an actual mill?) to make the one dudes extension plates
_Loctite blue - I have access to red 2400 at my work, I presume that is to be used only for permanent things tho
_Various lengths/gauges of silicone wire
_ Battery cells - need a solid answer on whether or not compression packed 30/40Ts can fit in HAYA channels
Drive train solution - no idea about this part. Though it’s important to know before I make my TV order, because if I go belt I’d presume I could just get my pully’s from them in the same order.
Still need a helmet that’s glasses friendly, have a few in mind right now, will update soon. LIGHTWEIGHT is a HUGE factor for me because of current neck problems.
If there’s anything else I’m forgetting, you have answers to my questions, or any other input, PLZ REPLY
Thanks all
