So Im on an budget of around 300ish$ I picked out these parts and I think that they are compatible and that the parts wont blow up when i connect them together.
Im planning to cut out the deck from an snowboard deck I made this already with a flexible one and it turned out to be amazing, I have the trucks already and will make my own mount and weld it on calibers/paris trucks
So these are the parts Motor: https://hobbyking.com/en_us/turnigy-aerodrive-sk3-6364-213kv-brushless-outrunner-motor.html
Battery:2x https://hobbyking.com/en_us/multistar-high-capacity-6s-5200mah-multi-rotor-lipo-pack.html (If i did my calculations right it should get me about 22km in series and 11km in parallel, I do not know how to calculate the speed it seems very complicated for me)
Are these parts compatible? And what could be the max speed if someone is kind enough to calculate it, also im about >90kg also dual motor setup is considered for the next year, also im worried how long would this board last since im 16 years old do not have a job (during the school year) and live in Croatia where the average paycheck is about 600$ per month
Id like to have a plug in charger inside the board, what are the prices of those as i do not want to disassemble the whole board and assemble it again just to charge it.
I found the pulleys on ebay for about 15$ http://www.ebay.co.uk/itm/DIY-Electric-Skateboard-ABEC-Flywheel-Pulley-Kit-15mm-Wide-Belts/352102591845?rt=nc&_soffid=5023314104&_soffType=OrderSubTotalOffer&_trksid=p5731.m3795
its 15:36 (ive seen that this is good,ill trust you guys )
I still haven’t done research on transmitters and receivers and their compatibility with the esc, but i just got an idea, is it possible to salvage the receiver and the transmitter from an rc car?
I have access to cnc machines at school so I might consider selling mounts for like 20$(i guess this is cheap) custom orders would be possible and the pulleys would be made from a material of your choice
