System:
Batteries: Ownboard 2P10S XT-60 42V full charge
Motors: Torque 6355
Switch: XT-90 Loop
Input: RC Car Pistol Grip Transmitter and Receiver
My eBoard worked until one of the two diyelectricskateboard ESCs shorted out. I had set up the board using vesc-tool and had no problems.
Now I’m using a flipsky Dual FSESC4.20
Plugged everything in and noticed the remote worked to spin the motors before running the vesc-project tool. Very promising!
Ran the entire motor wizard without a problem. I can spin the motors, brake, etc. while connected using the computer inputs. I did set it up as BLDC not FOC.
Ran the input wizard using ppm remote. Nothing but the Messages: “Applying Pulselengths Failed” & “Please activate RT app data and measure Pulselengths first”. I see no signal from the remote on vesc-tool.
So the remote worked before I tried the input wizard but not after.
Same remote as on my previous setup. In fact everything is the same except the dual ESCs. Remote is definitely paired to the receiver. I’ve tried other channels besides channel two, which worked before. Nothing.
To be honest, I bought an oversized Dual FSESC6.6 and hooked it up and had the same problem! I thought the remote input to that dual ESCs was faulty. So I bought the better sized Dual FSESC4.20.
Now I realize I’ve done something wrong! I don’t know what.
ANY SUGGESTIONS WOULD BE MOST APPRECIATED!
Cheers
