Yeah that’s what I said lol I don’t think it was understood properly lol
Oh sorry i didnt understand that properly. English is not my first language haha
So the 260kv motor products/electric-skateboard-motor-6355-260kv?variant=712632074263
8s2p batteries
And thd focbox is the way to go right http://www.enertionboards.com/electric-skateboard-parts/FOCBOX-programmable-brushless-motor-controller/
on off power switch
The remote
That’s alright! Good luck with building
Thanks man does anynone know a good guide or where i can buy covers for my components
Your English is perfectly fine I understood what you meant and you are correct series produces the same range as parallel.
As for the enclosures they can be made or you can buy them at a few places like DIYElectricSkateboard or I think Miami electric boards? And I think @MasterCho on this forum sells them too
Also @Eboosted sells some…its not difficlt to find somone to make custom one for you just ask in the general chat
Yo guys i designed the circuit could you guys check for mistakes or improvements i also would like to use a bms wouls that profit my system or isnt it worth it i also alwant to add a battterylife indicator maybe this one https://hobbyking.com/en_us/zippy-compact-5800mah-8s-25c-lipo-pack.html?___store=en_us Hope i did my homework well haha
This is the on/off switch products/on-off-power-switch-electric-skateboard
Yes that is correct. Instead of getting an on off switch I would suggest a antispark loop key. One because the switchs sometimes break very easily and if you have a s just get a bestech one and it will already have a switch on it
Hey guys what do you think of leaving out the BMS because the battery will almost never overheat because of its capacity compared to the motor and instead put a battery power meter in its place like this one, for instance, seems like a good plan?
Hey guys I would like to realise my build but idk how I need to connect everything to each other for instance: when i replace the BMS with a power meter how do I make it like it is a full circuit. And can i just plug my motor into the Vesc or isnt that possible?
Reaad more Motor is connected by the bullet conenctors to the vesc… If you dont have BMS you will have to charge it with a hobby charger Power meter connects red and black wire (plus and minus) and it should be behind the switch…
Hey man i did some research and i found out that maybe this would be a good bms what do you think for my 80A motor?
That won’t work it is for lifepo4 cells you have lipo. And you don’t need 80a, 60a will be fine
And it is 24S BMS, you will have 6s batteries of different chemistry… these two can be used if you would bypass them only for charging (you would have to solder more wires together, cheaper): https://hobbyking.com/en_us/6s-li-ion-10a-pcm.html https://hobbyking.com/en_us/6s-li-ion-pcm-charge-4a-discharge-10a.html
Or this one used for both discharging and charging: https://www.ebay.com/itm/6s-24v-Li-ion-Lithium-Cell-60A-18650-Battery-Protection-Board-BMS-PCM-Balance/152483333427?epid=705838451&hash=item2380b70533:g:Y4UAAOSwi0RXyWAW
There are lot of BMSes on ebay and anywhere else…the most favourite are BesTech BMSes and SUPOWER, thy are pricey, but worth the money
For more info and differences about BMSes, read more…search the internet, use google…there is no good article about BMSes here from what I know…
I don’t think that’s correct. Are you trying to run 6S + double-range, or 12S?
Ahhh I thought it was one of the ones when you just plug in the amount of wires you need and it will charge any number up to 24s
No thats hobby style charger
He will be running 6s2p
Yeah but you can get bms style ones like that I think I saw one at bestech it said something like 8-16s
Might exist, would not buy, waste of money.
