I guess now is as time as any to start a build thread.
This has been an ongoing project since late January. Due to various painful delays this board still resides on my kitchen table . The parts are as follows:
NS El Jefe Deck
Caliber 2s
Kegel Wheels
Bones Reds Bearings
2x 5s1p 26650 Batteries in series
OllinBoards VESC
TB 14T Motor Pulley/36T Wheel pulley
Tacon 245kv
Psychotiller Mount (delayed)
Custom Kydex Enclosure (Heat gun + time = ?)
GT2B
10s BMS (eventually)
XT90s on/off
Iām building this in hopes that I can commute the 3 miles one-way to work and back and do various other errands around town. This would also save me from having to ride the shitty Washington DC Metro everyday (those unfamiliar please visit https://twitter.com/unsuckdcmetro for highlights).
Most of the heavy lifting has been done on this project. Iām currently just waiting for a shim from psychotiller so that the mount can be fit securely. After that, I should be able to throw some wires together and take my first test run.
@scrant Iām interested in seeing a Kydex enclosure Iāve often thought it would be a good material for esk8, but wondered if it is sturdy enough. Keep us posted!
@treenutter - Iāve tried Kydex. Kydex is pretty good if thick enough. Fairly similar to ABS just easier to heat up and mold. They use it for gun and knife holders.
Yeah the main enclosure iām building is out of .118 kydex which feels like overkill. I also have so .028 lying around to do a simple motor/belt debris shield later down the road.
I have 5 different builds. 3 different belt sizes. Too many combinations of pulleys, and center to center distances to have 1 belt fit all of them.
Thatās why the center distance calculator is so important to all of us.
In 5m, if you divide the length of the belt 255 by 5 you get the number of teeth.
Finally done! I was able to get everything thrown together and working smoothly!
I placed everything into my wonky kydex enclosure and mounted it to the deck using a second set of skate hardware. The initial idea was to use tnuts and epoxy them in for a cleaner look, but with one quick mistake with the drill - I was through the deck and looking at other options. I also gave up on the psycho mount and went over to the tb v4 option. I just couldnāt get the psycho mount to have a good clamp on the hanger. The width of the v4 mount of the truck is much wider and feels rock solid now that itās mounted.
Also, I had a crazy simple idea to throw a volt meter onto a male charging plug as aneeded as-needed fuel guage. I can leave it in and ride or just check it before and after my trip.
@kyo It is 8.5inches wide in the center of the board.
I was surprised when I measured just now. I wear a US 11 shoe and usually like riding wider boards and the El Jefe is plenty. The concave is aggressive too.
