Could you please name this build? Something like The Samurai | (specs of board) it helps to keep things organised. Thanks.
I dont know about this specs,
What do you think?
Theres this Turnigy Aerodrive SK3 - 6364-245kv Brushless Outrunner Motor at the same price but 245kv Can go 4mph faster based on this calculator.
Though I need to focus on it’s ability to climb hills rather than speed, Thanks
Trust me, you will get very bored on a setup like this. That is pretty much my setup now and it doesn’t feel fast but it has decent torque. I would go with a 245kv motor or maybe up your battery voltage.
Thanks for the advice @lox897 Then maybe this Turnigy Aerodrive SK3 - 6364-245kv will work well?
It has the same price as the sk3 190kv. The last pic I uploaded shows out its specs.
Yes. That would work.
Turnigy Aerodrive SK3 - 6364-245kv will still be able to give me decent hill climb right?
Yes. Your best option would probably be going to 10S and 190kv (more expensive though). @torqueboards has used 245kv. I wonder what he thinks about the hill climbing ability of 245kv with 6s.
It’s enough. It’s the exact same setup that I use for charging my batteries (also same exact specs)
I would be carfully with this “power supply”. I had a similiar one which got very very hot at 4A… So i just charged at 1A… Maybe you better try a PSU like this. I would select about 100W to go safe.
Thanks, though I figured it would be much cheaper to just get IMAX B6AC V2 Professional Balance Charger/Discharger, instead which already has a built in power source.
Do you mind telling me where you got your template for your board, I’m going for the boasted board look as well.
