Assuming the Nunchuk receiver is connected to the master VESC, you need to enable it twice: first in the general app tab and second in the side Nunchuk tab. After that, you need to klick “write config” and then “reboot” (reboot is important!).
The blue led on the receiver should stay on when connected with the transmitter, not blinking.
@elkick OK, so I now know which is master, it has the Nyko receiver connected to it but the blue LED on the receiver is blinking, is there a way to reset the receiver or some other type of kick start?
I assume that you connected the can bus with the middle pins only (which would be correct)?
Also, just check again that the cables to the Nunchuk receiver are connected in the right way. Powering off/on the VESCs sometimes help to reset things. And always make sure to klick reboot (after “write config”) when changing values.
Ok, I got the receiver to stop blinking, one VESC seems to be responding, the slave does not. YES the canbus is correct. I’ve been at this all day, kinda going crazy!
@elkick yes, those are all done. All of a sudden everything shut off. I don’t know what happened but I suspect the battery just went below the allowable voltage. I had not charged the battery from new. So I have it charging now, hopefully with a full charge everything will turn back on. Assuming it does, I’m going to reflash the firmware on the slave. I read on another post that might be the issue. Thanks again for all of your help!
@elkick Well the battery is now 100% charged. Neither VESC is turning on. If I look under the VESC there is a red LED that is dimly lit. Anyone have any ideas what I should do next?
Correcting my previous post after inputs from @chaka and @elkick.
Pin 1 Do not use
Pin 2: Green SCL/RX. (closest to motor wires)
Pin 3: Blue SDX/TX
Pin 4: Do not use
Pin 5: Black GND
Pin 6: Red 3.3v
Pin 7: Do not use (closest to battery wires)
I only once had this strange behavior as well, it was related to a power connector not being plugged in strong enough and the VESC didn’t receive enough power (voltage). Also it might be an idea to check the battery for voltage supply at the end where the VESCs are connected: are all those soldering spots ok, connectors ok and all the cells providing the voltage they should?
So after a lot of help from @chaka and a new pair of VESCs from him, I was finally able to ride my project. Chaka was invaluable in getting my project running. The VESCs arrived with proper flexible wires, heat shrink pre-cut to accept the appropriate connectors, oh and most importantly working. Once I began to install them I had a few questions and Chaka immediately called me with all the answers to my questions.
This is a proper vendor! Never once did he complain because I had questions as a matter of fact he seemed to enjoy helping a fellow Eboarder. Folks, if you want to buy Eboard parts or accessories and don’t want to have to walk on egg shells with the vendor, do yourselves a favor and don’t hesitate to contact @chaka!
The first ride was a bit scary, this thing is POWERFUL, if you do more than crack the throttle you will be horizontal very quickly! I adjusted the parameters on the BLDC Tool and it took on a much kinder personality on both the throttle and brake. I’m sure I’ll get more comfortable the more I ride it but even the short rides I did today brought me big smiles
OK update time. with more help from @chaka, I’m really fine tuning this thing. First I must mention that Dual Drives are unnecessary unless you live in a hilly town, I weigh a svelte 225lbs and this thing on default settings was scary. After modifying the settings several times (each time reducing power and throttle aggressiveness) I’ve finally gotten the ole girl to behave. I’ve reduced the motor max, the throttle ramp and Erpms all in an effort to tame her. I’m really glad these VESCs are programable.
I can’t stress enough the customer support I’ve gotten from @chaka, top notch!
